Activity Forums Apple Final Cut Pro Legacy Final Cut Capture Machine
  • Final Cut Capture Machine
    Posted by Stuartmx on October 10, 2006 at 6:22 pm
    If I have a separate G5 setup just as a capture machine and share the hard drive, can I access files stored on the shared drive using another machine while the capture machine is capturing? Or will this cause a drop in frames?
    Stuartmx replied 19 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
