Activity Forums Apple Final Cut Pro Legacy Final cut can’t open!!!
  • Final cut can’t open!!!
    Posted by Samir Kassab on May 29, 2011 at 10:46 am
    hi guys
    i downloaded the trial version of Avid media composer 5.5 on my macbook pro.now when i open final cut it gives me a message that final cut quit unexpectedly,cuz of avid AVCHD codec! i uninstalled Avid and its codecs , trashed the FCP preferences , restarted and still getting the same message!all the other FCS applications are working perfectly though !
    is there any tips before i uninstall my FCS and reinstall it again ??
    Samir Kassab replied 15 years, 3 months ago 2 Members · 4 Replies
  • Samir Kassab
    May 29, 2011 at 1:26 pm
    sorry i was i a hurry , i wrote the error msg wrong! it goes “final cut pro quit unexpectedly while using the AvidAvdAVdncodec plug-in” …. i removed FCS and reinstalled it again … still getting the same message!
    this is getting really annoying
    any help please!
  • Everest Mokaeff
    May 29, 2011 at 1:54 pm
    Instead of re-installing FCS try to remove plugin that generates error.
    Free-lance fcp editor in Moscow
    http://www.mokaeff.com
  • Samir Kassab
    May 29, 2011 at 1:57 pm
    i did that … is there any other place i should search other the plug-in folder inside the application’s “show content “??
  • Samir Kassab
    May 29, 2011 at 3:06 pm
    thanks Everest,i’ve found it !
    its was neither in the application’s content folder , nor in the library/supporting files/fcp supporting files/ nor in the avid plug ins …. it was simply in the library / quicktime folder 🙂
    thanks again
