Activity Forums Apple Final Cut Pro Legacy Final Cut Audio Popping-Again
  • Final Cut Audio Popping-Again
    Posted by Chris Bierlein on February 11, 2009 at 5:11 pm
    I have a strange variation on what seems to be a common problem. I’m capturing footage shot on an HDX900 with 2 channels of audio. Audio playback is clean on tape, yet has a popping sound (like some dynamic filter is switching on and off) once captured. This also occurs when the clips are exported as standalone quicktimes. The strange thing is that the problem goes away when I export to tape, and when I monitor audio and video externally. Any thoughts?
    Chris Bierlein replied 17 years, 7 months ago 2 Members · 4 Replies
  • Chris Borjis
    February 11, 2009 at 5:14 pm
    shouldn’t you be monitoring externally any way? (from a console)
    I never use the built in-audio for fcp monitoring.
  • Chris Bierlein
    February 11, 2009 at 5:24 pm
    Perhaps, but when I export a Quicktime to post for clients, there’s that popping (that I’m not hearing through the external). How do I work around that one?
    http://www.chrisbierlein.com
  • Chris Borjis
    February 11, 2009 at 5:28 pm
    ah.
    I’m really frustrated at apple for not having better QC
    on the quicktime development.
    sounds like a quicktime issue. try an update or downgrade.
    or maybe try trashing quicktime preferences if there is one.
  • Chris Bierlein
    February 11, 2009 at 5:35 pm
    Will try! Thanks.
