Activity › Forums › Apple Final Cut Pro Legacy › Final Cut and Rotoscoping….
Posted by Lokidrummer on November 3, 2005 at 1:21 amHi, I have Final Cut Pro HD (4.5) can you rotoscope in this? If not what program will i need? Thanks
-Will
Chris Poisson replied 20 years, 10 months ago 5 Members · 4 Replies -
Andy Mees
November 3, 2005 at 3:12 amIf you want to assemble the elements and composit them on the timeline, then no problem.
If you want to do the cutting and masking then FCP’s tools may not be your perfect partner.
You might want to look at AE and/or Combustion. -
Jeremy Garchow
November 3, 2005 at 3:26 amMotion si worth a look too (if you have studio). Their B SPlines work okay.
After Effects would be good too as Andy says.
G5 Dual 2Ghz <> 4GB RAM <> FCP 5.02 <> Kona 2
ATTO 42XS <> Huge Systems 4105 Fibre -
Kevin Monahan
November 3, 2005 at 4:58 am -
Chris Poisson
November 3, 2005 at 3:19 pmSilhoutte Roto will blow you away. https://www.silhouettefx.com/ Absolutely the best.
