Activity › Forums › Apple Final Cut Pro Legacy › Final Cut and DVD Burning
Posted by Chris Baker on January 18, 2011 at 4:43 pmHere’s an odd one and not sure where to ask this. I have a completed wedding and it plays fine on the timeline but when I burn a copy to DVD for the client to watch there are weird pauses and skips. Tried it a few times and they are always in the same places which ruled out the blank media. Any ideas?
Chris Baker replied 15 years, 8 months ago 4 Members · 9 Replies -
David Roth weiss
January 18, 2011 at 4:49 pmI’ll bet you did one or both of the following two things:
1) you fiddled with the bitrate and raised it up beyond the default in the preset
2) you did not use the AC3 preset and you created you DVD with PCM audio
If you did one or both of the following then you most likely have exceeded you set top player’s overhead for DVD playback, hence the skipping.
David Roth Weiss
Director/Editor/Colorist
David Weiss Productions, Inc.
Los Angeles
https://www.drwfilms.comPOST-PRODUCTION WITHOUT THE USUAL INSANITY ™
A forum host of Creative COW’s Business & Marketing and Apple Final Cut Pro forums. Formerly host of the Apple Final Cut Basics, Indie Film & Documentary, and Film History & Appreciations forums.
Michael Sacci
January 18, 2011 at 4:51 pmMost likely it is your bitrate and/or you are using PCM audio instead of ac3 audio. And it can be your media also. It doesn’t have to be just one thing. But since you have but no real info it is hard to say.
David Roth weiss
January 18, 2011 at 4:55 pmCome on Michael, go get yourself another cup of java… You’re a little slow on the draw today. 🙂
David Roth Weiss
Los Angeles
David Roth weiss
January 18, 2011 at 5:48 pmEcho… Echooo….. Echooooooo………….
David Roth Weiss
Los Angeles
Michael Sacci
January 19, 2011 at 2:49 amWell David, if I’m just a little behind you I’m going okay.
David Roth weiss
January 19, 2011 at 2:57 am[Michael Sacci] “I’m just a little behind you I’m going okay.”
Very, very smooth… You may be a little behind, but you’re in excellent form Michael.
David Roth Weiss
Los Angeles
Chris Baker
January 20, 2011 at 2:13 pmThanks for the help guys! I’ll try that solution in Compressor today and see how it goes.
Visit us at;
http://www.frogpondproductions.biz
(860)884-6015The creative urge is the demon that will not accept anything second rate.
-Agnes DeMille -
Chris Baker
January 20, 2011 at 2:17 pmAs far as other info is concerned it is 1hr16mins. Nothing too complex as its just a wedding.
Visit us at;
-Agnes DeMille
