Activity › Forums › Apple Final Cut Pro Legacy › Final Cut and CGI
Final Cut and CGI
Posted by Boofer on July 29, 2007 at 11:20 pmWill final cut ever be used to make a Cgi film as good as transformers? Or better question yet why didn’t they use it to make transformers?
Walter Biscardi replied 19 years, 2 months ago 3 Members · 3 Replies -
Walter Biscardi
July 29, 2007 at 11:40 pmYou mean create the CGI or do the final edit?
Walter Biscardi, Jr.
HD Editorial & Animation for Broadcast and independent productions.All Things Apple Podcast! https://cowcast.creativecow.net/all_things_apple/index.html
Read my blog! https://blogs.creativecow.net/WalterBiscardi
Alexander Gao
July 30, 2007 at 8:51 amHmm… if you are asking if Final Cut will ever be capable of producing CGI like you saw in Transformers, then the answer would be no. Final Cut is a non-linear editing system that is used for editing and cutting film and video. The CGI you saw in transformers, on the other hand, was created with high-end 3D packages. I’m not sure what program, but among the industry standards are Autodesk Maya and Softimage XSI. Final Cut is used in many many hollywodd blockbuster films, but it is not a CGI tool, nor is any other non-linear editor out there such as Avid.
Alexander Gao
USC School of Cinematic Arts
John C. Hench D.A.D.A. -
Walter Biscardi
July 30, 2007 at 9:19 am[boofer] ”
Will final cut ever be used to make a Cgi film as good as transformers? Or better question yet why didn’t they use it to make transformers?”If you’re talking about the final edit, then that’s the decision of the editor who is cutting the film. Whatever tool they use is the one that the film will be cut with.
Final Cut is being used by Walter Murch to cut films such as “Cold Mountain” and “Jarhead” so it is being used to cut major motion pictures. That’s the most famous example and I’m sure there are others out there.
