Activity › Forums › Apple Final Cut Pro Legacy › Final Cut AJA Capturing out of sync!
  • Final Cut AJA Capturing out of sync!
    Posted by Robert Stone on July 6, 2009 at 9:11 pm
    This JUST started happening on my FCP sytem. When capturing over SDI from XDCam the audio is consistently 16 frames out of sync. Doesn’t matter which capture setting I use. Anyone have any thoughts on how to cure this? This has been a reliable system for 3 years until now!!
    Bobby Stone
    ATOMIC FILMS, INC.
    Richard Sanchez replied 17 years, 2 months ago 4 Members · 4 Replies
  • Chris Borjis
    July 6, 2009 at 9:47 pm
    whats the xdcam footage frame rate?
    are you capturing from the sdi out of an EX camera?
    have you tried xdcam import…
    need more details…
  • Richard Sanchez
    July 6, 2009 at 10:58 pm
    I’ve been experiencing this a lot lately with DVCPRO HD shot on an HDX 900. I haven’t found any pattern (it happens on both very full and brand new raid sets). It’s fairly inconsistent, and not very frequent so I’ve just set those off sync clips offline, and recaptured.
    Richard Sanchez
    North Hollywood, CA
    “We are the facilitators of our own creative evolution.” – Bill Hicks
  • Gary Adcock
    July 7, 2009 at 1:42 pm
    [Richard Sanchez] “I’ve been experiencing this a lot lately with DVCPRO HD shot on an HDX 900. I haven’t found any pattern (it happens on both very full and brand new raid sets).”
    OK
    what has changed on your systems?
    have you done ANY OS or Software updates or installed anything new on your computer?
    Did you check to see if there was a driver update- and if you did update the driver did you check the firmware to see if it needed a separate update from the driver?
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
    Check out
    https://www.aja.com/kiprotour/
    Inside look at the IoHD
    https://library.creativecow.net/articles/adcock_gary/AJAIOHD.php
  • Richard Sanchez
    July 7, 2009 at 5:54 pm
    Using OSX 10.5.6, FCP 6.0.5 and Kona 3 with Kona software 6.0.3, but also saw it with Kona software 6.0.2. Also, the Kona firmware is the 64 bit DMA.
    It’s pretty sporadic, and is fixed by a quick recapture. It sounded like Robert’s experiencing this more regularly.
    Richard Sanchez
    North Hollywood, CA
