Activity › Forums › Apple Final Cut Pro Legacy › Final Cut – After effects
Posted by Shannon Bedford on August 10, 2010 at 8:24 amI need to supply several pieces of vision to an After Effects editor. I tried this with a clip, exported uncompressed as a Quicktime (default settings).
He hasn’t been able to use this clip.What settings should I be using?
My vision is HDV1080i50 and I have my timeline set to match.Thanks
S Bedford, Western Australia
Walter Soyka replied 16 years, 1 month ago 4 Members · 3 Replies -
Shane Ross
August 10, 2010 at 9:47 amMachines without FCP cannot view the HDV codec. When you exported from FCP as a QT movie, you kept the HDV settings, and they couldn’t see it.
Export as ProRes or the Animation codec. They will have to export to the animation codec to get it back to you.
Shane
Read my blog, Little Frog in High Def -
Adam Taylor
August 10, 2010 at 9:50 ami thought the AE system needed to have FCP installed to use the Prores codecs?
but i may be wrong.As AE works across macs and pc’s, it might be worth asking the AE operator what file types he needs.
Adam Taylor
Video Editor/Audio Mixer/ Compositor/Motion GFX/Barista
Character Options Ltd
Oldham, UKhttp://www.sculptedbliss.co.uk
Walter Soyka
August 10, 2010 at 10:19 am[adam taylor] “i thought the AE system needed to have FCP installed to use the Prores codecs?”
FCP must be installed to be able to encode ProRes, but ProRes can be decoded on both Mac and Windows platforms. The most recent version of Quicktime includes a ProRes decoder. For older versions of Quicktime, there are also separate decoders available for free download from Apple:
https://support.apple.com/downloads/Apple_ProRes_QuickTime_Decoder_1_0_for_Mac
https://support.apple.com/downloads/Apple_ProRes_QuickTime_Decoder_1_0_for_WindowsIf the artist is using CS3, there will be a gamma shift in AE on ProRes footage with the default interpretation rules. The solution to this problem is here.
[Shannon Bedford] “What settings should I be using? My vision is HDV1080i50 and I have my timeline set to match.”
Unless you are going back to HDV tape, you might consider transcoding and working in ProRes timeline. HDV is very heavily compressed, and it’s not really suitable for effects work.
Walter Soyka
