Activity Forums Apple Final Cut Pro Legacy final cut adding frames on export qt conversion
  • final cut adding frames on export qt conversion
    Posted by Jonah Maddox on March 3, 2009 at 11:38 am
    Im having problems with an export. Basically i do loads of these all day everyday, and i havnt had this problem before.
    When i export from my fcp sequence with QT conversion to H.264, 25fps, 433×243, medium quality on one particular video i am getting a frame here and there added when watching playback.
    The frames are added at cuts in the sequence from a music video, so a cut will happen but there will be a one frame flash of the original shot before, which obviously destroys the whole edit.
    I can only remember having this problem with this one video, but it is a normal music video sent over on digibeta captured with an AJA Kona codec same as always.
    I fixed this previously by exporting individual cuts and then re-importing them to the sequence, but Im hoping someone may know why FCP is doing this.
    Thanks in advance for any help.
    Jonah Maddox replied 17 years, 6 months ago 1 Member · 0 Replies
  • 0 Replies
