  • Posted by Tasmyn Shirlaw on October 14, 2013 at 8:11 am
    Hello All
    Please can some one give me a quick low down on final Cut transfers
    I am in SA so we use PAL
    Betacam SP – Hard Drive
    DV – Tape (vise versa)
    Maybe having a few other tips might help me
    I am a rentals and Transfers Coordinator at Digital Film Service..
    Please.. Help 🙂
    Tasmyn Shirlaw replied 12 years, 11 months ago 2 Members · 2 Replies
  • Shane Ross
    October 14, 2013 at 5:33 pm
    For DV…simply connect the deck to the computer via Firewire. Launch FCP. Choose the DV/NTSC Easy Setup…then go into LOG AND CAPTURE MODE. Make sure that the deck control on the deck is set to REMOTE.
    For BetaSP…you’ll need a third party capture card. AJA.com, decklink.com, matrox.com. Install the card and the drivers for it. Connect the card to the deck with the best connections possible (Component is the best, unless you have a deck with SDI connections), and RS-422 deck control. Then choose ProRes NTSC as your Easy Setup, and choose the card for your deck control (you’ll have to set up the card to capture the signal too…that would be in the card manual).
    Shane
    Little Frog Post
  • Tasmyn Shirlaw
    October 15, 2013 at 6:27 am
    Thanks Shane 🙂
    Okay, This has made my life a whole lot simpler… 🙂
    I have an AJA and a 422, This shall do.
    Thanks again! 🙂
    AS/A Levels
    Set Work
    Junior Edit Assisitant
    Junior Rentals
    Management Skills
    Panavision- Camera and Lens Teq Training
    Visual Impact- Broadcast Rentals
    DigitalFilm Service – Transfers and Rentals -Coordinator
    Transfers- DFS
