Activity Forums Apple Final Cut Pro Legacy Final Cut 7 – Missing Plug-ins directory as well as vanishing plug ins
  • Final Cut 7 – Missing Plug-ins directory as well as vanishing plug ins
    Posted by Jordan Wise on September 13, 2009 at 6:08 am
    I recently switched over to Final Cut 7 (which is great by the way) and just obtained quite a few new plug ins I was hoping to incorporate into my work flow. However, when I go to search for my plug ins directory to install them (/Library/Application Support/Final Cut Pro System Support/Plugins), it is no longer there.
    As an alternative I’ve tried placing these plug-ins inside (/Library/Preferences/final cut pro user data/plugins) to no avail.
    As I start to get suspicious, I load up FCP7 and check my effects tab and notice that a few key transitions I use have seemed to have vanish from my effects folder (flashframe, wind blur cross). They still work when I load a project that has them, but thats the only way to view them now. There presence in the effects tab is no longer there.
    While looking around to try and resolve this issue, I installed the plug in manager from apple, but now I’ve noticed that some filters don’t work as a result of that (specifically text assembler which worked prior to that installation and now all I get is a layer thats white with no text whatsoever)
    I’m now finding myself scrambling for solutions in order to meet a deadline. I’ve tried scouring the web for a solution but have turned up empty.
    If anyone at all can shed some light on my problem(s) it would be greatly appreciated.
    Noah Greenwood replied 13 years, 10 months ago 6 Members · 9 Replies
  • 9 Replies
  • Jeremy Garchow
    September 13, 2009 at 2:31 pm
    Are these third party plugs or stock fcp?
  • Jordan Wise
    September 13, 2009 at 3:04 pm
    Well flash frame, and wind cross blur I believe are stock.
    But I’m not 100% sure if Text Assembler, which resides in ‘3D text projects’ under ‘Master Templates’ is part of Boris continuum 5 or stock.
    In an effort to solve the problem I actually re-installed my copy of BCC5, just to see if it was the problem, but it hasn’t changed a thing.
  • Jordan Wise
    September 13, 2009 at 3:15 pm
    I should also note that I have been using FCP7 for a week and a half before any of these problems showed up. Just opened it one day and had to deal with these issues all at once.
  • Jeremy Garchow
    September 13, 2009 at 3:52 pm
    Quit FCP and trash your prefs. Reopen your prject and make sure to check the option under:
    Effects > Effect Availablity > All Effects
    Here’s a picture for reference:
    Jeremy
  • Jordan Wise
    September 14, 2009 at 11:01 am
    Did a system restore which resolved the conflict with the white screen caused by the plug in manager, so the text assembler effect is now restored. However, the issue with the flashframe and wind cross blur still remains. I took your advice and changed the effect availability to ‘all effects’. Unfortunately, it didnt resolve the issue.
    This is just too weird. Is there a way to save transitions off the timeline back into the effects tab? That’s the only thing I can think of to restore these transitions.
  • Ishu Krishna
    June 23, 2010 at 10:32 pm
    I noticed the same thing. Those two are too much too soon plugins, and not fcp plugins. All my other third party plugins that I use work fine, but I can’t seem to find where they are being stored in FCP7. Too much too soon plugins are txt files and not a dmg installer. I have no idea where to put them and I am not able to use flashframe or wind cross blur, my favorite transitions.
  • David Roth weiss
    June 23, 2010 at 10:41 pm
    Why don’t you drag the alias onto your Browser’s “PLACES” area, over on the left side? That way the directory will be there and available when you need it.
    David Roth Weiss
    Director/Editor/Colorist
    David Weiss Productions, Inc.
    Los Angeles
    EPK Colorist – UP IN THE AIR – nominated for six academy awards
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, Indie Film & Documentary, and Film History & Appreciations forums.
  • Travis Hunt
    May 5, 2011 at 4:16 am
    Look for the application support directory on your system disk, not the library folder for your user.
    It should be there.
    Travis
  • Noah Greenwood
    October 5, 2012 at 11:59 pm
    huge fan of your movie dave!
