Activity Forums Apple Final Cut Pro Legacy Final Cut 7 audio issue
  • Final Cut 7 audio issue
    Posted by Shawnda Hughes on March 23, 2019 at 1:56 am
    I am editing in Final Cut 7.
    The source video has 48.0 KHz/32 bit floating audio.
    Final Cut sequence options only have settings for 8, 16 or 24 bit.
    Is there any way to make this work?
    Thanks in advance for any assistance.
    Shawnda
    Roger Poole replied 7 years, 2 months ago 2 Members · 2 Replies
  • Roger Poole
    March 23, 2019 at 11:57 am
    Go to settings. Choose the 48k pre set. Duplicate it then change the sample rate to 32k. Save that setting as whatever 32k and it will be available to you.
  • Roger Poole
    March 23, 2019 at 12:02 pm
    Sorry, misread. But under the same process you can make changes to most anything.
