Activity › Forums › Apple Final Cut Pro Legacy › Final Cut 7 and Matrox MX02 mini – can’t get external viewing
Posted by Bob Duthaler on September 21, 2012 at 3:46 pmI am unable to get any external viewing on my monitor with Final Cut Pro and the MXO2 mini. I see the settings for all the sources there (including the matrox ones) but when I go to the “all frames” settings on the external view I get this error: The specified hardware could not be found, check your camera connection.
Oliver Sitompul replied 13 years, 11 months ago 3 Members · 4 Replies -
Jerry Hofmann
September 21, 2012 at 5:30 pmMake sure the settings in the Matrox control panel match those of your sequence’s and source clips.
Then choose the matching setting in the video and audio output selections in the bottom of the View menu.
Then turning on external viewing should work OK.
If your box isn’t connected, you’ll get that message too… so check that for sure. Also in the control panel, it will report it doesn’t see a box if the connection isn’t right.
There is an uninstaller for the Matrox software in your apps folder, try uninstallng and then reinstalling the proper drivers for your OS and version of FCP. And give it all another go.
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
Current DVD:
https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
Oliver Sitompul
October 17, 2012 at 11:32 amDid you fixed this problem? I’m having the same problem with my mxo mini
Bob Duthaler
October 17, 2012 at 2:58 pmNoi we have not. I here there may be some new drivers out in November that may help, but nothing now.
Oliver Sitompul
October 17, 2012 at 3:51 pmI just received a reply from a tech guy @matrox:
We have some hardware changes on a latest production of the MXO2 boards whereby old drivers cannot be installed.
The solution will be upgrading the OS X to Snow Leopard version 10.6.8 and installing MXO2 driver version 2.5.0.0034. Officially 2.5.0.0034 driver is comparable with OS X Lion 10.7 however, works perfectly fine with Snow Leopard 10.6.8 and is the latest driver that supports FCP 7.0.3.Perhaps we have similar problem..? My mbp came with leopard and haven’t had any issues, until now..guess i’ll need to upgrade in order to use the mini.
