Activity Forums Apple Final Cut Pro Legacy Final Cut 6 – Editing with varying frame rates
  • Final Cut 6 – Editing with varying frame rates
    Posted by Shaun Du sart on January 23, 2008 at 5:48 am
    Hi all,
    This is my 3rd post in Creative Cow’s forums (you can search my name for my other two posts) as I am working on a short film shooting on a Panasonic HVR 202. I have been put in charge of the post production end of the project.
    The director has just informed me that the D.O.P will be shooting 3 different frame rates 25, 50 and 60.
    Will I be able to edit these three frame rates on the one timeline in Final Cut 6? Any help will be greatly appreciated as always.
    Shaun
    Shaun Du sart replied 18 years, 8 months ago 3 Members · 3 Replies
  • Paul Escandon
    January 23, 2008 at 6:22 am
    The short answer is yes, you can. There may be some big stumbling blocks however depending on how much you’re going to have to mix and what the purpose of all the multiple frame rates was.
    Is the majority of the film shot at 25fps and the 50 and 60 footage was shot as overcrank material to be slowed down to 25? If that’s the case, then that is probably the best case scenario and you should be able to work in a 25 frame rate timeline without any problems. If, however, stuff was shot at 60i and it needs to be mixed with an equal mix of 25 and 50 stuff, then you may have some headaches on the horizon. I guess the more information you have the better.
    But to answer your question on whether or not it can be done in Final Cut – the answer is yes. Biggest thing to find out first is what the majority of the stuff is shot in and that will likely be your timeline setting.
    Paul Escandon – Lead Editor @ Outdoor Channel
    Producer | Director – Oremus Productions
    http://www.oremusproductions.com
    Apple Certified Trainer – Final Cut Pro
    Adjunct Professor of Media – JPCU
    MacPro Quad-core XEON
    8Gb ram, ATI Radeon X1900 XT, 2TB internal RAID
    2 20″ Dell UltraSharps + Matrox MXO & 23″ ACD
  • Arc Nevada
    January 23, 2008 at 7:14 am
    Shaun you sound worried. I have not heard of that Camera by Panasonic but I am wondering if the camera came bunded with Edius Broadcast? Panasonic was bundling Edius Broadcast with their highend Cameras at one time because it was the only software that worked well with the P2 cards. Edius also works with the Grass Valley JPEG 2000 HD cameras. I think it would be wise to invest in Edius if you use Panasonic cameras.
    Read this article.
    https://www.studiodaily.com/studiomonthly/reviews/f/nles/7023.html
    It is indeed true RT not just an RT preview using a laptop. You can even add effects and mix DV-50 and HD-100. You can use MPEG and uncompressed in the mix if you want.
  • Shaun Du sart
    January 23, 2008 at 10:53 pm
    Hey,
    Thanks for the reply posts!
    My mistake the camera is actually a Panasonic HVX 202 (using P2 cards). I will check on what frame rate the majority of the short will be shot at, but I’d assume like what you said that it will be 25 and the 50 and 60 will be slowed down.
    I will post again. Thanks!
