Activity Forums Apple Final Cut Pro Legacy Final Cut 5, slowed down with new Decklink drivers
  • Final Cut 5, slowed down with new Decklink drivers
    Posted by Alexander Feichter on October 1, 2005 at 4:05 pm
    hello all,
    after i’ve installed the newest decklink-drivers because of a stuttering playback problem now the timeline scrubbing has become extremely slow. also there is a little redrawing-problem at the top of the timeline. just where you touch and move your cursor.
    8 and 10 bit, both slow.
    if i put an animation compressed quicktime in the timeline that is indicatet as “not rendered” i can scrub through it perfectly fast as with everything else before…
    dual 2.7, enough ram and enough disk-speed
    thanks for any tip
    alex
    Alexander Feichter replied 20 years, 12 months ago 1 Member · 1 Reply
  • Alexander Feichter
    October 1, 2005 at 4:15 pm
    aaah! if i set the effect handling to “decklink sd” then then it’s quick like before. but i loose all my realtime effects… 🙁
