Activity Forums Apple Final Cut Pro Legacy final cut 4.5 won’t recognize my video (consumber 16×9 LP footage firewired dubbed to sp)
  • final cut 4.5 won’t recognize my video (consumber 16×9 LP footage firewired dubbed to sp)
    Posted by Ammioz on October 7, 2005 at 8:21 pm
    Help!
    Trying to cut some footage for a friend. Problems arise because 1) they shot it in LP (so I had to dub it to sp so I could use it, my main deck is a JVC BRDV3000) 2) also, they shot it in basic camcorder 16×9. The problem is, I cant hear any audio during playback or prevew/capture. The audio meters are responding vigorously. Also FC is telling me that no video is present when I try to capture it. I went back to the original LP footage, using a little canon mini dv camra as the deck adn tried importing it from that source. Same problem. I know that there is audio there because I can hear it through the little camaera’s speaker and I can see the audio meters.
    Any suggestions would be greatly appreciated. Gear-wise I’m cutting on a 17″ G4 titanium, 1.3 ghz, 1 gig ram.. latest version of tigher and quick time 7..
    Ammioz
  • Bouncing Account needs new email address
    October 7, 2005 at 8:41 pm
    [ammioz] “I know that there is audio there because I can hear it through the little camaera’s speaker and I can see the audio meters.”
    That is exactly what is supposed to be happening.
    The audio is, by default, intentionally MUTED to the Mac’s speaker output during Log and Capture.
    So you should normally monitor the audio directly from the camcorder or deck you are using to capture. (It is the preferred method.)
    CAUTION:
    Many people have reported that noise or “pops” appear in the captured clips if the Mac’s internal audio is left on WHILE capturing… so may want to choose “Off During Capture.”
    However, there is a way you can turn ON the Mac’s speaker if you really WANT to:
    In FCP4x and earlier:
    Final Cut Pro (menu) > Audio/Video Settings… > Capture Presets (tab)
    “Duplicate” the Capture Preset you are now using, when the window opens rename it (I added “MacAudioOn” to the file name).
    Click open the “Advanced” button in the Audio section and turn speakers to “ON during Capture.”
    The Mac speakers/audio-out will now play Audio during the preview in the Log and Capture window.
    In FCP5x and later:
    In the Record Tool:
    Clip Settings, near audio buttons, choose: Preview: “ON”
  • Ammioz
    October 7, 2005 at 9:01 pm
    Thanks Matte
    But why wont it recognize the video?
    October 7, 2005 at 9:33 pm
    The first thing to always try is to Quit FCP, Restart the Mac, Open your FCP project and try again.
    Next:
    THE FOLLOWING COMES FROM THE KEN STONE WEBSITE:
    “Over 5,000 years ago Confucius wrote: ‘If you are toiling away, you have changed nothing and FCP heads South on you, [starts behaving in strange ways] then it is time to trash your FCP Preferences.’ ”
    Click the following link for instructions.
    https://www.kenstone.net/fcp_homepage/trashing_fcp_prefs.html
    A great way to do this is to use “FCP Rescue” a free Apple Script that will Trash the Preferences for you (and restore nearly all of your user settings afterward).
    There are versions for FCPro & FCExpress.
    Download these free Apple Scripts at
    https://fcprescue.andersholck.com/
    This is one FCP tip that has helped in hundreds of “odd” problems..
