Activity Forums Compression Techniques Final audio out of sync when using compressor
  • Final audio out of sync when using compressor
    Posted by Paul Hasler on September 19, 2005 at 12:32 am
    Hi
    When i compress i file in compressor from FCP the audio jumps out of sync when i look at it in DVD Studio Pro. I thought it might have been when i was doing a quick test with a faster compression however when i increased the quality it was still out of sync.
    If there are any ideas on how to fix this it would be greatly appreciated.
    Paul : )
    Paul Hasler replied 20 years, 11 months ago 2 Members · 2 Replies
  • Aaron
    September 20, 2005 at 6:23 pm
    Have you run DVDSP in simulation mode or are you playing it out of the DVDSP sequence? Have you tried doing a sample build and previewing prior to burn with DVD Player?
    -Aaron
  • Paul Hasler
    September 21, 2005 at 5:26 am
    yeh i have tried it in simulation mode and the audio is out of sync when i look at it there too. The final product is also out of sync when played on a DVD player. I am not sure whether it is something i am doing in DVDSP or whether it is when i actually compress it that it is losing sync. When i export from FCP i run Compressor and just use the generic 60min High Quality Setting to compress it.
