Activity Forums Adobe After Effects Final Animation for TV – Bitrate and audio Problem
  • Final Animation for TV – Bitrate and audio Problem
    Posted by João Queirós on November 28, 2014 at 10:25 am
    Hi all,
    I´ve done an animation at 720×576. Square Pixels. Frame Rate: 25 fps. The animation have 20 seconds.
    When i do the final render in after effects. I choose MPEG2. And i wanted the bitrate to have at least 16 Mbps. But it gives me only 4.20 Mbps. What can i do?
    And the audio needs to come together with the video. And in this format the audio comes apart in a *.mpa extension. Help please.
    The video settings for the video on the TV channel are these:
    Vídeo
    • Format: MPG2
    • Bit rate mode: Constant
    • Bit rate: 20.0 Mbps(minimum)
    • Width: 720 pixels
    • Height: 576 pixels
    • Display aspect ratio:
    Original
    • Frame rate: 25 fps
    • Chroma subsampling:
    4:2:2
    • Scan type: Interlaced
    • Scan order:Top Field First
    Thanks in advance.
    Kindly Regards,
    João Queirós
    https://www.joaoqueiros.com/uk_index.php
    João Queirós replied 11 years, 9 months ago 1 Member · 0 Replies
  • 0 Replies
