Activity › Forums › Apple Final Cut Pro › Final cut pro
Final cut pro
Posted by qiang lin on January 2, 2024 at 4:01 pmMacBook HDMI external monitor is running Final Cut Pro, FCPX does not display the monitor with HDMI? What’s going on? Please let me know.
Jeremy Garchow replied 2 years, 8 months ago 4 Members · 4 Replies -
Daniel Hirsh
January 2, 2024 at 5:34 pmYou may need to set up an external display in system settings> displays
Jeremy Garchow
January 3, 2024 at 10:56 pmRan across this today with some AJA Devices and macOS 14.1. Had to do some Terminal commands, and then the connection was restored:
https://support.apple.com/en-us/108387
support.apple.com
Starting in macOS Sonoma 14.1, cameras and video output devices that don't use modern system extensions won't be available to use unless you restore the legacy settings.
