filter/select ALL comps in Project window
I have not found a way yet to easily filter all comps in the project window.
I’m sometimes using a script which requires to select/highlight all comps it should be applied to.
When working with Projects that have over hundred comps, scattered around in sub sub sub folders it becomes tedious to get them all.
… and one wrong click while control selecting and I need to start over.is there any way to filter out all available comps inside of the project window? or any other possibility to select all comps?
