Activity Forums Adobe Photoshop Filters on empty layers
  • Filters on empty layers
    Posted by Todd Schmidt on June 10, 2011 at 6:38 am
    Hey all,
    I’m pretty sure this can’t be done, but I’ll ask anyways. I use After Effects all the time and it’s so easy to do this so I’m hoping Photoshop can as well. I would like to drop Knoll light factory flares onto an empty layer so I can move, adjust and composite on top of other layers. I see that you can’t drop filters onto empty layers which is a pain. After Effects allows you to drop effects like Video Copilots Optical flares onto solids and the composite and can adjust on top of others. Also in AE you can drop effects onto an empty adjustment layer and it will composite on layers below. I do know about filling a layer with black then adding light factory and changing the blend so screen. I might be talking in circles but I hope I’m getting my point across. Is there any way pf doing this?
    Scott Roberts replied 15 years, 3 months ago 3 Members · 4 Replies
  • Richard Harrington
    June 10, 2011 at 12:18 pm
    No filter adjustments
    You can apply many filters as smart filters (convert layer to smart object first).
    I case of flares… can make a black empty layer and apply filter (then set it to screen mode)
    Richard M. Harrington, PMP
    Author: From Still to Motion, Video Made on a Mac, Photoshop for Video, Understanding Adobe Photoshop, Final Cut Studio On the Spot and Motion Graphics with Adobe Creative Suite 5 Studio Techniques
  • Todd Schmidt
    June 10, 2011 at 3:35 pm
    Thanks Richard…that’s what I suspected. I did create a black layer set to screen and applied Knoll to it. I’m hoping Photoshop take s a page form it’s sister program After Effects and starts making better composting adjustments with more control.
    June 10, 2011 at 4:03 pm
    Try applying effects to smart objects… then click the blending controls inline with the effect.
  • Scott Roberts
    June 19, 2011 at 3:08 am
    I’m a user of After Effects as well and wonder when the two programs will merge into one – the two apps are starting to overlap in capabilities. There are some things I do in After Effects, on a single, high res frame, apply effects and save to be dropped into a photoshop composition for print work.
    LittleBlackBird.net
    GraphicsDump.com
