Activity Forums AJA Video Systems filters cause output buffer wierdness on LH 8 bit clips
  • filters cause output buffer wierdness on LH 8 bit clips
    Posted by Bob Flood on January 27, 2006 at 4:27 am
    hi guys
    dual g5, kona lh, fcp 5, os 10.4 promax SATA raid
    i have some footage captured betacam component to 525 29.97 8 bit uncombressed and when i dropped brightness/contrast and a gamma corrector filter on a clip in an 8 bit sequence, the nTSC out got all messsed up, like a three way split with the clip running in 2 boxes along the top, squished verticaly, and another clips just looping the same one second segment over and over in the lower 3 fifths of the screen (it was kinda cool effect)
    i can see if i am pushing the rt, but shouldnt i at least get dropped frames or de rez? this output looked like a sick card
    any ideas? sound familiar to anyone?
    thanx in advance
    bee eph
    Bob Flood replied 20 years, 3 months ago 2 Members · 2 Replies
  • David Battistella
    January 28, 2006 at 3:17 pm
    Are you trying to play this back ten bit? I have seen this when you attempt to play 8 bit through 10 bit of K2.
    Is your RT set to “safe” ?
    That’s all I can think of at this moment.
    David
    I can’t believe it’s not butter!
  • Bob Flood
    January 29, 2006 at 4:22 pm
    David
    thanx!
    its an 8 bit clip in an 8 bit sequence. Once i render the range its fine.
    its also not consistent
    i will endeavor to gather more facts as i did not suprevise the job from the start.
    bee eph
