Activity Forums Apple Final Cut Pro Legacy filters and effects not working
  • filters and effects not working
    Posted by Coulter Mitchell on October 1, 2007 at 6:30 pm
    In FCP 5.1.4, I have a very large project that has a lot of effects in it. The other day, all the effects worked fine. Today however, when I opened the project, the same effects don’t work. When I go to the filters tab, they’re all still there. But when I add new masks, they don’t show up even after they’re rendered. If I apply new effects, nothing shows up no matter how much I adjust it.
    Jacqueline Bazinet replied 17 years, 6 months ago 6 Members · 12 Replies
  • 12 Replies
  • Tom Wolsky
    October 1, 2007 at 6:34 pm
    Trash your preferences and see if it fixes it.
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP6,” “Basic Training for FCS2” and “Final Cut Express Made Easy”
    Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 3.5 HD Editing Workshop”
  • Coulter Mitchell
    October 1, 2007 at 7:09 pm
    Thanks. How do I trash preferences? I can’t seem to figure it out.
  • Coulter Mitchell
    October 1, 2007 at 7:28 pm
    I figured out how to trash my preferences. Unfortunately it didn’t fix the problem. The effects still aren’t showing up. Any other ideas? Thanks!
  • Coulter Mitchell
    October 1, 2007 at 7:29 pm
  • David Bogie
    October 1, 2007 at 10:10 pm
    Be sure to check the other forums where you have posted this same question. Maybe one of them has an answer for you.
    bogiesan
  • Jacqueline Bazinet
    June 21, 2008 at 1:53 am
    I’m having the same problem. I’ve been using FCP for 5 years, never seen this one. I am currently using FCP 5.1.4 on a MacBook Intel 2Ghz Core 2 Duo. OS 10.4.11, 1 GB Ram.
    Effects and filters were working, then one day I noticed they weren’t working. The basic transitions work, dissolves, etc. But no color correction, no audio filters. You can place the effect on the clip, but it has no “effect” at all.
    Trashing preferences doesn’t fix this, as you found out.
    Did you ever find out what happened? I’m about to re-install FCP.
    Jacquie
  • Pete Stringfellow
    November 14, 2008 at 6:20 pm
    I ended up re-installing FCP…. which worked, for a couple of weeks…now, here I am AGAIN!!!!
    Did anyone ever figure this out? Re-installing isn’t the solution. :-/
  • Legra Swing
    March 24, 2009 at 6:55 pm
    Did you figure out what the problem was or how to fix it? I am having the same problem. Please let me know
  • Legra Swing
    March 24, 2009 at 6:56 pm
  • Pete Stringfellow
    March 24, 2009 at 7:08 pm
    Yes, I did actually. :-/
    So the deal is that for SOME reason…Apple has decided that if you have more than one video card, you’re SCREWED!
    Yep…. did you recently add another video card to your system? I have 3 and it doesn’t work. I bought another machine and tested it….worked perfectly (it only has one video card in it).
    I ended up calling a friend of mine who works for Apple…obviously they don’t publicize this bit of factual knowledge, but that’s the answer.
    Doesn’t Apple know that video professionals use more than one video card??? It’s ridiculous if you ask me.
    Good luck bro!!! Let me know what you do.
