Activity Forums Apple Final Cut Pro Filter Used Clips
  • Emmanuel Tenenbaum
    February 3, 2014 at 10:58 am
    Jasper thanks to you I discovered a new feature, thanks a lot for your answer! And discovered the concept of role, which is intersting.
    I’m afraid though it doesn’t help me to do what I wanted. I wanted to delete all proxy files from my project (I have more than 900 clips…), then select at once all the ones that are used, and then re-render the proxies for those clips only.
    Do you know if there is any way to do that ?
    Thanks!!
    Emmanuel Tenenbaum
    https://emmanueltenenbaum.com
