Activity Forums Adobe After Effects Filter Question
  • Filter Question
    Posted by Thosia on April 2, 2006 at 6:13 am
    I am relatively new to After Effects.
    For a transition I would like to let the picture go away in parts (perhaps 10) which are of different size. The parts should slowly drift away into different directions (right, left, down, up).
    I don’t mean something like shatter or so. Just a going apart in one simple dimension.
    I know it’s old fashioned. But I’d like to use it. I’ve seen it several times before. Is there a AE filter to help building the effect?
    Thanks.
    Eric Gross replied 20 years, 5 months ago 2 Members · 1 Reply
  • Eric Gross
    April 4, 2006 at 12:40 am
    I’d like to know this too.
    I suppose you could do something with a tiled image, where you had say 10 different colors shapes and then applied a displacement map according to the different red and green values.
    Then just key frame the amount of displacement.
