Activity Forums Apple Motion Filter on 3d group causes objects to vanision from 2d, non-perspective, views?
  • Filter on 3d group causes objects to vanision from 2d, non-perspective, views?
    Posted by Steve Mclelland on July 22, 2010 at 12:58 pm
    I’m used to AE and have to transition to Motion 4.02 for a project here so, maybe this is an easy one and I’m just not seeing the switch.
    If you have a 3d group with say 2 items, and then you switch the view to Top or Left say, they show as you would expect, nice lines with 3d handles. For some reason when you apply a filter to the group though, all items within the group disappear from all 2d, non-perspective, views. Is this right?
    If the filter is applied directly to each item within the group, they remain visible.
    This is really annoying if this is the expected behavior. This means that either I need to never apply filters to groups or never rely on the top/left/right/etc views.
    Here is a pic showing illustrating it
    Steve
    Sacha Thomas replied 16 years, 2 months ago 3 Members · 3 Replies
  • Mark Spencer
    July 22, 2010 at 4:31 pm
    Yes I see the same behavior, regardless of whether the filter is forcing the group to become rasterized to layer order or not – seem like a bug to me. Not a deal-killer for me, if you select the group, you still see the controls for moving and rotating it, but it is annoying I agree.
    Mark Spencer
    Freelance Producer/Editor/Motion Graphics Artist
    Apple-certified Master Trainer
    Author, Motion 4 from Peachpit Press
    https://www.applemotion.net
  • Steve Mclelland
    July 22, 2010 at 5:10 pm
    Thanks. Glad it wasn’t just me. Yeah, I guess if you know about the behavior and you keep your layers opened and select them first you can deal with it. It is quite a pain when you are trying to set up 10 layers, each at various z positions I’ve found that the way to go is to disable the filters first, set all of your layer z positions, then turn the filters back on. Of course the other option is to apply the same filter set to each individual layer and never apply it to a group.
    Maybe in the next dot release…
  • Sacha Thomas
    July 23, 2010 at 2:33 pm
    This appears to be limited to a version 4 issue. It does not happen in Motion 3.0.1.
