Activity Forums Apple Final Cut Pro Legacy Filmflash Transition in Final Cut Pro 7
  • Filmflash Transition in Final Cut Pro 7
    Posted by Gonzalo Hernangómez on March 7, 2015 at 8:23 am
    Hi all!
    I’m trying to do a filmflash transition in Final Cut Pro 7. What I’d like to do is something similar to this:
    https://www.youtube.com/watch?v=mIOAqO6Trvw
    Playing with the Gaussian Blur Filter and with Levels doesn’t seem to do the trick, I’m not getting that cool red tone that you can see in the tutorial.
    Does anybody know what filters should I apply?
    Thanks a lot!
    Mark Suszko replied 11 years, 5 months ago 3 Members · 4 Replies
  • Roger Poole
    March 7, 2015 at 4:31 pm
    I have a flash transition which looks the same from Luca’s plugins, (free), I had a quick look on the web but I can’t see it in the current lineup. However, if you do a search you might find it.
  • Roger Poole
    March 7, 2015 at 4:49 pm
  • Gonzalo Hernangómez
    March 7, 2015 at 8:28 pm
    Thanks a lot Roger! Unfortunately I need it in a place where I can’t install external plugins, but I will use it at home. Does anyone knows a way to do it with the built in presets?
    Thanks again 🙂
  • Mark Suszko
    March 9, 2015 at 1:47 pm
    Set up dissolves into and out of a slug of white, or reddish-white, in your case. The added flavor comes from keyframing some changes to black and white levels of the clips in the 3-way color corrector, and from changing the blending mode (what Apple calls Modify>Composite Mode)
