Activity Forums Adobe Encore DVD Film over two streams
  • Film over two streams
    Posted by Matt King on December 16, 2007 at 2:11 pm
    I have a film that is on two tapes which i have encoded.
    The film is just under 2:30 long so it is going on a dual layer.
    What is the best way in Encore to author this.
    I have authored loads of films but always from one stream.
    So far i have just created two timelines and used the ‘End action’ to go to the next stream, but if I ‘rewind’ once i am on the second stream it wont rewind back to the previous stream.
    I also tried putting the films in the same timeline but although the video would go in the same video layer the audio would only go on to separate layers.
    I have wasted a lot of DLdiscs.
    Jeff Bellune replied 18 years, 8 months ago 2 Members · 4 Replies
  • Jeff Bellune
    December 16, 2007 at 2:29 pm
    You must make the audio in one stream match the audio in the other stream. Then you will be able to put both streams in a single timeline and have the audio remain on a single track.
    It wasn’t clear from your post if you are using elementary video and audio streams or if you are using muxed program streams (video and audio together in one file).
    This case is one of the reasons that I recommend using elementary streams instead of muxed program streams. With elementary streams you could just replace the audio without re-encoding the video, too.
    -Jeff
    The Focal Easy Guide to Adobe Encore DVD 2.0
  • Matt King
    December 16, 2007 at 4:27 pm
    Thank Jeff,
    Yes they are elementary streams, I agree I never use programme streams for the same reason.
    When you mean match audio, are you talking bit-rates?
  • Matt King
    December 16, 2007 at 4:50 pm
    Did a bitrate convertion on both streams and it worked
    cheers
  • Jeff Bellune
    December 16, 2007 at 5:15 pm
    Glad it worked out. 🙂
    -Jeff
