Activity Forums Apple Final Cut Pro Legacy Film flicker from light on set
  • Film flicker from light on set
    Posted by Steve Radley on October 18, 2005 at 7:29 pm
    Does anyone have a technique or a plug-in that can get rid of a flicker from a non-flicker free light on the set? It was shot on super16 at 48 fps and transferred to NTSC at 24 fps.
    Steve Radley
    Orlando
    Gavin Stokes replied 20 years, 11 months ago 3 Members · 2 Replies
  • Jerry Hofmann
    October 19, 2005 at 2:11 am
    yikes… didn’t anybody see this on the set?
    I can’t think of an easy workflow at all… possibly fixable in a frame by frame correction… yikes. might be easier to re shoot…
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Gavin Stokes
    October 20, 2005 at 12:03 am
    If there’s a discernible cadence (every Xth frame is darker, for example), you could quickly write a Shake expression to adjust the brightness on those frames.
    Of course, you have to have access to Shake…
