Activity › Forums › Adobe After Effects › Film Flicker Effect?
Posted by Remington Markham on March 25, 2010 at 4:12 amI’m looking to simulate a film flicker effect, not over the top and cheesy.
I figured the best way to go about it would be with a strobe effect, but I can’t seem to get the right numbers for the duration and period?
Any suggestions?
I’m shooting on a Panasonic TM300, 60 fps (interlaced)
Remington Markham replied 16 years, 6 months ago 3 Members · 4 Replies -
Michael Szalapski
March 25, 2010 at 1:14 pmWhy not add a wiggle expression to the opacity of a black solid. For more control you can add expression control sliders and tie your wiggle numbers to them.
– The Great Szalam
(The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)No trees were harmed in the creation of this message, but several thousand electrons were mildly inconvenienced.
Ahmed Abd el-rahman
March 25, 2010 at 1:53 pmcreate a black solid then create a hold key frame on the opacity with a value of 0 then after 3 frames change the opacity to 80 then after 3 frames change it to 0 you will notice that all key frames is a hold key frame because we want the opacity to be flicking rather than fading in and out .
after that Press Alt + Click on the opacity stopwatch and write the loop expression
LoopOut(Type=”cycle”)
and that’s it if this not help please inform me
Michael Szalapski
March 25, 2010 at 2:29 pmI see your post on another forum received a similar answer as well as a sample project file!
– The Great Szalam
Remington Markham
March 25, 2010 at 4:59 pmThanks! I completely forgot about the loop expression, that’s perfect because it gives me complete control. A wiggle expression was my first idea, but I realized it wouldn’t be a consistent flicker.
