Activity Forums VEGAS Pro Film effects
  • Film effects
    Posted by Marksh on October 23, 2006 at 5:39 am
    Hi-
    I wanted to know if vegas or a plugin for vegas had a “80s squiggle line effect” Its kinda hard to describe. If anyone saw the dire straits music video “money for nothing” you may know what I am talking about.
    Also is there another way to make a slow motion effect with out right clicking on the clip and going into properties? becasue the slowmotion seems to become very choppy.
    Mark
    Edward Troxel replied 19 years, 10 months ago 3 Members · 4 Replies
  • Don Bloom
    October 23, 2006 at 12:01 pm
    There are a lot of ways to accomplish the squiggle look. Satish has some of those effects in his WAX plugins, also Damaged Goods has that look in their plugins.
    As for slow motion it depends on when you see it look choppy, if you see that in the preview, I wouldn’t worry about it as generally once rendered out it’s fine BUT it depends on how slow you make the clip AND whats going on in th eclip. If you have a lot of right to left or left to right motion covering th efull frame you could have a problem with choppiness. If so then slow it down a bit at a time and render it out – IE, if you want to slow the clip down to say 20% of original, then try 50% and render, then slow down the new render by 25% and render etc. however I can tell you that I personally have never had to do that and I slowed clips down to 10%. Properies is one way to slow a clip down, you can also add a VELOCITY envelope and slow it that way OR hold down the CNTRL key and pull the RIGHT edge of the clip to the RIGHT unti you have slowed it down to where you want OR a combination of the 3.
    Don
  • Marksh
    October 23, 2006 at 6:35 pm
    thanks ill look into that.
  • Marksh
    October 23, 2006 at 6:50 pm
    Can you send me a link to damaged goods becasue I can not seem to find it. thank you
  • Edward Troxel
    October 23, 2006 at 7:00 pm
    It’s in Vol 4 #1 of my newsletters.
    https://uvtvproductions.com/damaged.html
    There’s a review of the product there.
    Edward Troxel
    JETDV Scripts
