Activity › Forums › Adobe After Effects › Film conversion help.
  • Film conversion help.
    Posted by Arnold Foote on March 18, 2007 at 4:32 am
    Dear All,
    I have shot a nice TV spot on 35mm and my film house gave me 24p hd files to edit.
    I have edited quite fine but I want to convert the file to 29.97fps for broadcast. Is this the correct thing to do and how on earth do I do this.
    Edited on FCP and added graphics on AE7. I want to export at 29.97 but whe I do, I get jitter.
    J
    jj.foote@mac.com
    Arnold Foote replied 19 years, 5 months ago 5 Members · 7 Replies
  • 7 Replies
  • Steve Roberts
    March 18, 2007 at 9:23 am
    Check the Help on “pulldown”.
  • Solie Swan
    March 18, 2007 at 1:37 pm
    You may also want to take a look at Standards Conversion from http://www.nattress.com which converts between NTSC, PAL and 24p right within FCP. Within AE Magic Bullet (I know it goes from 30i to 24 p but may go the other way too) and Twixtor may do it as well. Andrew Kramer also has a tutorial on frame rate conversions you can look at (videocopilot.net)that does not involve any 3rd party plugins.
  • Arnold Foote
    March 18, 2007 at 2:26 pm
    Thanks everyone, I will check it out and let you know how it goes…
    jj.foote@mac.com
  • Brendan Thompson
    March 18, 2007 at 11:33 pm
    Remember that when converting from 24 to 30 fps you are repeating repeating some of the fields (I can never remember which ones). This becomes a problem when you have slowed down a shot or when a shot pans quickly. Some frames will have fields that are so different from one another it causes a stuttering effect. So you might still get some stuttering even after your pulldown.
  • Arnold Foote
    March 18, 2007 at 11:39 pm
    Thanks for that but now I have another problem.
    The footage I digitized was at 126 MB/sec or so, and after I did my after effects work, the data rate seems to be 28Mps. This info is from the FCP program window. What am I doing wrong for me to lose so much data?
    jj.foote@mac.com
  • Kevin Camp
    March 19, 2007 at 4:51 pm
    this is probably a better question for fcp forum, but you said you had hd to edit? what preset did you use to edit in? did you edit in a non-hd preset? it may be that your original footage was in a fatter codec than what you editted in, like a differnce in dvcprohd and hdv, and fcp may have converted/rendered the footage to the lesser codec. or possibly the footage was edited in a standard def preset, where the same effect would probably occur.
    i haven’t worked much in fcp, i’m just theorizing…
    Kevin Camp
    Designer – KCPQ, KMYQ & KRCW
  • Arnold Foote
    March 29, 2007 at 6:31 pm
    I will check that out… thanks
