Activity Forums Apple Motion Film Burn Look
  • Film Burn Look
    Posted by Aaron Aphasia on November 28, 2007 at 4:50 pm
    Is there a way to build a film strip burn in Motion? I want to have an image freeze, then change to sepia and burn/melt as a transition. Just not sure how to go about it but it seems like it should be easy enough. Thanks for any advice, Aphasia
    Tim Burgess replied 18 years, 8 months ago 4 Members · 4 Replies
  • Noah Kadner
    November 28, 2007 at 11:18 pm
    I’d do a search for some tutorials. Also you can do much better and more realistic effects with stock footage- try:
    https://www.istockphoto.com/index.php
    https://www.artbeats.com/
    -Noah
    Unlock the secrets of the DVX100, Apple Color and now the HVX200!
    https://www.callboxlive.com
  • Burt Hazard
    November 29, 2007 at 2:02 pm
    You could animate a rough ellipse mask shape and use animated color filters.
  • Aaron Aphasia
    November 29, 2007 at 3:05 pm
    THANKS!
  • Tim Burgess
    December 29, 2007 at 12:02 am
    I’ve done a paper burn animation – it may be of interest to you. It takes a displaced paper image (courtesy of Dave Nagel) and scales up the Corona emitter with a custom shape. I also use a copy of the shape with a radial gradient to produce a scorched outline before the flames. The project is at https://homepage.mac.com/timburgess/motion/Paper Burn.sit
    Tim Burgess
    Magnetic Island
