Activity Forums Maxon Cinema 4D Filleting edges created by boolean subtraction
  • Filleting edges created by boolean subtraction
    Posted by Michael Banjoko on July 23, 2010 at 11:52 am
    I have created razor sharp hole edges in an earth mound but i need these edges well rounded. How do i do this, especially where the parent ‘A’ object has a curvature.
    Adam Trachtenberg replied 16 years, 1 month ago 2 Members · 1 Reply
  • Adam Trachtenberg
    July 23, 2010 at 3:40 pm
    If you modeled the holes with coherent geometry you could select the edges along the rim and use the bevel tool. If you used booleans, however, you’re probably out of luck. Cinema’s booleans tend to create chaotic geometry that’s very difficult to work with.
