Activity › Forums › Adobe After Effects › ‘Fill up’ layer/shape with particular
  • ‘Fill up’ layer/shape with particular
    Posted by Bas V breugel on March 27, 2012 at 8:47 pm
    Hi guys,
    I would like to fill a country with tomatoes….
    I have 3 layers;
    – imported a eps of the country (map shape)
    – imported a illustration of a tomato
    – particular on a solid.
    I tried to do so with Layer as the emitter, but nothing happens (made the country layer a 3d layer).
    any suggestions?
    Kevin Camp replied 14 years, 6 months ago 3 Members · 2 Replies
  • Tudor “ted” jelescu
    March 27, 2012 at 8:51 pm
    Trapcode Form may be a better option for this.
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Kevin Camp
    March 27, 2012 at 9:00 pm
    that should do it… but here’s the process:
    1. new comp and add the custom particle layer (tomato) and emitter layer (country).
    2. make the country layer a 3d layer.
    3. add a new solid and add particular. set emitter type to ‘custom’ and then select the country layer emitter layer and you’ll probably want the velocity set to zero. also set the particle type to ‘custom’ and choose the tomato layer as the particle layer.
    if you ram preview at this point you should get tomatoes popping up all over the coutnry. you’ll probably want to tweak the particles/sec and the size and life span of the particles (for starters).
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
