Activity › Forums › Maxon Cinema 4D › Fill spline shape with Mograph Clones
  • Fill spline shape with Mograph Clones
    Posted by Jon Herron on February 11, 2009 at 6:47 pm
    Curious if there is a way to fill a spline shape with mograph clones.
    I realize the spline effector allows for attaching to the spline itself, is there a way to fill it????
    i.e: A text spline filled with evenly spaced cubes.
    thanks
    Adam Trachtenberg replied 17 years, 7 months ago 3 Members · 6 Replies
  • Brian Jones
    February 11, 2009 at 11:34 pm
    yes, cloner in object mode and use the spline as the object
  • Adam Trachtenberg
    February 12, 2009 at 6:33 am
    That’s pretty much going to do the same thing as the spline effector.
    The only way I can think to do it would be to extrude the spline, make it editable, weld the caps, and use the resulting object in a volume effector set to control visibility.
  • Adam Trachtenberg
    February 12, 2009 at 2:30 pm
    EDIT: it seems that you don’t have to convert the extrude to polygons to use it in a volume effector, which is great as it keeps things parametric.
  • Jon Herron
    February 12, 2009 at 4:36 pm
    Cool, got that to work. Thanks for the tip.
    One question how do you set the volume effector to control visibility? …maybe im overlooking a setting
    Thanks again!
  • Brian Jones
    February 12, 2009 at 4:47 pm
    ahh, fill the empty space, not fill the spline….
  • Adam Trachtenberg
    February 13, 2009 at 2:47 am
    Check the visibility box in the effector’s parameters tab.
