Activity Forums Adobe After Effects Fill layer with layer
  • Fill layer with layer
    Posted by Jurjen Versteeg on January 17, 2014 at 2:46 pm
    Hi there,
    I want to to do a fairly simple thing, but can’t seem to find the right solution.
    I want to give 20 layers in my composition a fill of another layer.
    Sort of the “texturize” effect, but without the lighting options.
    Any ideas?
    Thanks a lot!
    I don’t want to Luma/Alpha matte every layer, because I need to do a ton of them 😉
    Roland R. kahlenberg replied 12 years, 7 months ago 3 Members · 5 Replies
  • Roland R. kahlenberg
    January 17, 2014 at 3:01 pm
    Place the Fill layer at the top of your Timeline layer stack and switch on its Preserve Underlying Transparency switch – it’s the T switch in the Modes section of the Timeline.
    HTH
    RoRK
    AE MoGraph Intensity Workshop – Promo Video
    Intensive mocha & AE Training in Singapore and Other Dangerous Locations
    Imagineer Systems (mocha) Certified Instructor
    & Adobe After Effects CS6 ACE/ACI
  • Philip Bowser
    January 17, 2014 at 8:01 pm
    Wow! I’ve never used this feature before! This is great. Thanks Roland.
    Philip. Bowser
    January 18, 2014 at 1:09 am
    It’s quite useful for other uses well since the top layer only appears when there are non-transparent pixels on underlying layers.
    Cheers
    RoRK
  • Jurjen Versteeg
    January 20, 2014 at 12:24 pm
    Hi Roland,
    Thanks! Great function, but it does not quite what I’m looking for.
    I want to texture to be on the layer itself. So when I rotate and position the layer, the texture should stick to it.
    Any ideas? Thanks!
    January 21, 2014 at 12:58 am
    Sounds like you need to parent the texture to the layer. Since there is more than one layer with the alpha channel, you can’t use the method I proposed. I suggest that you look into using a regular Track Matte or the Set Matte effect, together with a parenting structure.
    HTH
    RoRK
