Activity Forums Adobe After Effects Expressions fill color to audioamplitude
  • Adam Greenberg
    September 20, 2021 at 4:41 pm
    random ?
    first use keyframe assitant to convert audio amplitude to keyframes then expression the fill color to the both channels slider with the code below;
    then you can change the numbers to something else. You realize this will change the color at every frame though ?
    temp = thisComp.layer(“Audio Amplitude”).effect(“Both Channels”)(“Slider”);
    [temp/80, temp/100, temp/20, temp/20]
  • Darren Caruana
    September 20, 2021 at 4:48 pm
    thanks a lot for your help , as you sad that is too much color change but thanks again.
  • Adam Greenberg
    September 20, 2021 at 4:52 pm
    there are many ways to fix that with math, depending on what it is you want
