Activity Forums VEGAS Pro Filesize / rendering problem for Vegas/Youtube
  • Filesize / rendering problem for Vegas/Youtube
    Posted by Gary Beckwith on February 12, 2009 at 7:14 am
    I’ve read several similar suggestions about the settings for Vegas when posting to youtube (wvm, quality=best, bitrate=1m, 320×240…) and I have a couple questions:
    1) When I follow these instructions, I have a 122MB file that is only a little over 5 minutes. I’m pretty sure Youtube allows 10 minutes and 100MB, so I’d like to be able to have more than a 5 minute file on youtube. Is my compression ratio normal or should it be better?
    2) When I go to the “bit rate” tab on the rendering settings, all the options are greyed out. I can’t select/change the settings. The default is set to ISDN 500K, and I can’t change it. I’m using Vegas Platinum 9. Shouldn’t I be able to change the option to the suggested 1M?
    any help on these questions is appreciated!!!
    thanks
    gary in vermont
    Danny Hays replied 17 years, 6 months ago 3 Members · 3 Replies
  • John Rofrano
    February 12, 2009 at 12:36 pm
    > <>1) When I follow these instructions, I have a 122MB file that is only a little over 5 minutes. I’m pretty sure Youtube allows 10 minutes and 100MB, so I’d like to be able to have more than a 5 minute file on youtube. Is my compression ratio normal or should it be better?
    It’s not the compression ratio… it’s the bitrate. Try a template with a lower bitrate.
    You are using Vegas Movie Studio and the Movie Studio version does not allow you to customize rendering templates. You need to purchase Vegas Pro for that functionality.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Gary Beckwith
    February 12, 2009 at 4:09 pm
    thanks for the reply but…
    I have read many posts on various websites that recommend the 1M bit rate for Youtube. Are you saying that this only applies to videos of ~4 minutes or less? Why would everyone be saying to use 1M when the resulting file is too large for Youtube?
    I’m using Platinum 9 version, which actually does allow me to customize the rendering templates. I can click the “custom” button and all the tabs give me options to change, except the bitrate tab.
    I guess my version doesn’t allow me to change the bitrate, which is what you’re saying i need to do to get my videos to fit on youtube if they’re over 4 minutes? So I’m just SOL until I spend $450, or go back to Windows Movie Maker? Arg….
    thanks again for any advice
  • Danny Hays
    February 12, 2009 at 4:46 pm
    You tube now allows HD 720p 1 gig file upload limit now. Google you tube HD and read up on it. Danny Hays
