Activity Forums Adobe Premiere Pro File/Sequence List
  • File/Sequence List
    Posted by Eric Santiago on November 4, 2015 at 12:45 pm
    Is there any utilities that will export a sequence clip list or something that would tell me where a clip is being used as well as timecode?
    Working with a lot of files shot with a DSLR and its not as easy as my RED workflow.
    Eric Santiago replied 10 years, 10 months ago 3 Members · 7 Replies
  • 7 Replies
  • Jon Frost
    November 4, 2015 at 11:53 pm
    You could export an EDL – Edit Decision List.
    Jon Frost
    Easthampton MA
  • Eric Santiago
    November 5, 2015 at 1:59 am
    Exported both EDL and XML but its a mess to deal with.
    If I had some XML coding knowledge Im sure I can sift through it but was hoping for an Utility of some sort.
  • Eric Santiago
    November 5, 2015 at 2:26 am
    Found on helpful option in Project window.
    Turned on Video Usage and it allows me to see the clips sequence use.
    Thats helpful but again a nice text file would be best.
  • Stephen Abbott
    November 5, 2015 at 3:14 pm
    Hi Eric,
    I recently pushed out a lot of subclips into a spreadsheet. I’m also not really XML-literate, so I imported Premiere’s XML export into FCP7, then used the batch list export options to get a simpler text list. A bit of text bashing and it was spreadsheeted neatly. I realise this will be useless if you don’t have FCP7/Mac. In that case, send me a trimmed project as an XML export and I’ll sent it back in text.
    (Edit: I’m in South Africa / GMT+2, so depending on where you are this might take a little time to round-trip.)
    Stephen Abbott
  • Eric Santiago
    November 6, 2015 at 12:10 pm
    Hey thanks for the offer Stephen and great tip 🙂
    I have FCP 7 on an SSD put away so Im good at that point.
    Again thanks 🙂
  • Stephen Abbott
    November 6, 2015 at 12:32 pm
    A pleasure! FCP is very civilised in what it exports: you can hide and re-order the metadata columns for a neat custom export for less text-bashing down the line…
    Stephen Abbott
  • Eric Santiago
    November 6, 2015 at 1:47 pm
    I work mostly in RED and love the export options from REDCINE-X.
