Activity Forums Adobe Encore DVD Files won’t import
  • Files won’t import
    Posted by Stephen Lubin on November 8, 2008 at 10:06 pm
    I rendered a couple files in after effects and want to import them into Encore DVD. When I try to import, it says that it can only import files with 24 or 29.97 fps. The weird part is that the files I exported from AE were 29.97 fps. Not sure on what to do?
    Thanks in advance!
    -Stephen
    Joe Bowden replied 17 years, 10 months ago 2 Members · 5 Replies
  • Joe Bowden
    November 8, 2008 at 10:08 pm
    You might want to provide more information about the encoding of the AE files, and about your Encore project settings.
  • Stephen Lubin
    November 8, 2008 at 10:36 pm
    My Encore project settings are NTSC 4:3 and my AE settings are 720 x 480 with a frame rate of 29.97. I export using quicktime format in the compressed setting H.264.
  • Joe Bowden
    November 9, 2008 at 12:47 am
    I’m guessing it doesn’t like the H.264 compression. Which version of Encore?
    Instead, try exporting as QuickTime DV or uncompressed from AE, and then import that into Encore.
  • Stephen Lubin
    November 9, 2008 at 12:49 am
    I have Encore 1.5
    How do you export an uncompressed version of quicktime?
  • Joe Bowden
    November 9, 2008 at 12:55 am
    Encore 1.5 definitely does not support H.264 encoding. However, H.264 is supported in Encore CS3 and CS4.
    [Stephen Lubin] “How do you export an uncompressed version of quicktime?”
    Similar to how you exported H.264 from QuickTime – you select it in the video compression settings in AE. Keep in mind that uncompressed = large files. I’d suggest QuickTime-DV or MPEG-2 for DVD, if you version of AE supports the latter.
