Activity Forums Adobe Premiere Pro Files will not Share Same Sequence
  • Files will not Share Same Sequence
    Posted by Pat Ford on October 4, 2015 at 10:24 pm
    I am on windows received files from a Mac. I believe that video header files are munged up.
    I can’t get files from the output of a video switch and those from a camera to coexist on a sequence.
    I transcoded the camera .mts file to h.264…it works fine.
    It will not co-exist with the switch h.264 file on the same timeline. The sequence for the switch is 29.97 framerate. The sequence for the switch is 10 fps. It is showing a 15 frame rate in the project window.
    The file size is approximately the same as the camera mp4. I can transcode it to get a 29.97 frame rate but it will not share the same sequence.
    Interpret footage will not work.
    Since the original file seems strange, I believe this is not a problem with my workflow. My best guess is that the problem is a corrupted video header file.
    I need to take a different path…this has been horrible.
    Pat Ford replied 10 years, 11 months ago 1 Member · 1 Reply
  • Pat Ford
    October 5, 2015 at 6:33 am
    Problem solved! It appears think was not using the new “source patch” toggle properly. Can’t understand why this did not come up in the last project I cut.
    There were some issues with corrupted files in the mac>windows transfer…files were showing as 15fps. But I have good 29.97 footage from another source. Premiere is swallowing anything I can throw at it.
