Activity Forums Adobe After Effects Filename burn-in on render
  • Filename burn-in on render
    Posted by Daniel Frome on November 30, 2010 at 1:32 am
    Hi guys;
    I’ve got 300 or so odd clips that I need to render into quicktime movies. I would like AE to display (in the quicktime movie) the filename of whatever I’ve rendered.
    Is there such a script that I could apply in batch to these 300 or so files? Secondly, how would I go about installing/activating such a script?
    Sorry – AE noob here.
    Daniel Frome replied 15 years, 4 months ago 3 Members · 4 Replies
  • Chris Wright
    November 30, 2010 at 3:39 am
  • Kevin Camp
    November 30, 2010 at 3:52 pm
    if the script doesn’t do what you need, a simple way to create this is with an expression in a text layer.
    i’m not sure if you needed the name of the comp, or the name of a layer within the comp, but either way, you would create a new text layer and add an expression like this to the the text>source text of the text layer:
    // this will put the name of the layer just bellow the text layer in the text layer
    thisComp.layer(index+1).name
    // this will put the name of the comp in the text layer
    thisComp.name
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Kevin Camp
    November 30, 2010 at 4:04 pm
    if your source file for the layer was a different name than the layer, you could use this:
    // places the source file name in for the layer bellow the text layer into the source text
    thisComp.layer(index+1).source.name
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Daniel Frome
    May 11, 2011 at 3:06 pm
    Kevin –
    I never got to thank for you for your help!
    Is there a way to automate this process for say…several hundred clips? For example — importing a whole bunch of files, creating comps for each file with a text layer over each one and then applying this expression to burn-in the comp name?
