Activity › Forums › Apple Final Cut Pro Legacy › Filed/interlace issue with Quicktime export
Hugo Falsen replied 13 years, 9 months ago 6 Members · 25 Replies
Philip James
May 8, 2011 at 7:30 pmI’m now running this through Compressor. I’ve used Apple ProRes 422 for interlaced material (High Quality) and set Native Field Dominance to ‘Progressive’ in A/V attributes. Have I covered it or is there anything else I should take into account to have a successful de-interlace?
Philip James
May 8, 2011 at 8:22 pmThe resultant QT file from the above settings in Compressor didn’t solve the interlace issue.
Chris Tompkins
May 8, 2011 at 10:32 pmWhat are you trying to create here?
What is deliverable.Edit your video till it;s complete/done/approved/locked. Interlaced.
If your going to DVD -Leave it interlaced.
Going to web? When you compress for web, deinterlace.What is your deliverable?
Chris Tompkins
Video Atlanta LLC -
Philip James
May 9, 2011 at 9:08 amThanks Chris
Ultimately this is for web content. I shot the material and cut a selected rushes sequence in FCP. I’m then going to pass that on to a contact in the US who will cut it for web. I usually shoot 25P on my projects so not used to working at 50i. I just want the material to be watchable online. There is a lot of movement in this since it features runners – the field issue is therefore a big deal. I wanted to do any de-interlacing before I pass the material on.
Phil
Bouke Vahl
May 9, 2011 at 11:01 ameeer, if someone else is going to cut it after you, why not give them the original quality?
If the other side is a pro company, they will know what to do.
Otherwise your question has been answered several times…
Bouke
https://www.videotoolshed.com/
smart tools for video pros -
Philip James
May 9, 2011 at 11:26 amThanks Chris. It’s not going to a pro company but someone who will not know what to do with the interlacing issue so I’d like to address it for them.
I guess my question has been answered to a degree but my concern is that I haven’t been able to get results using the methods outlined. When using the de-interlace option in FCP QT export I couldn’t really see any improvement. Then I noted that you and Bouke suggested not using the FCP de-interlace but doing it as a separate stage. I then tried Compressor using the settings I outlined. That didn’t work either.
Am I missing something or could there be something else going on with this footage that can’t be addressed by de-interlacing?
I really appreciate your help on this by the way : )
Chris Tompkins
May 9, 2011 at 12:19 pmCan you tell them it’s interlaced and they need to deinterlace once done editing and then compressing for their deliver?
Chris Tompkins
Video Atlanta LLC -
Philip James
May 9, 2011 at 1:45 pmI need to keep it very simple – the person is very new to video content. I’m also concerned that I haven’t been able to address the issue at hand by doing my own de-interlace and I’m not sure why. If there is another issue going on I don’t want to pass that problem on.
Bouke Vahl
May 9, 2011 at 3:29 pmI don’t get what is happening.
The de-interlace filter in Compressor should give decent results.
The preview in compressor might be horrible, but a renders should do the trick.
Pick a few seconds of testing material and start experimenting.Bouke
