Activity Forums Apple Final Cut Pro Legacy file warning
  • Posted by Bob Vick on August 22, 2005 at 2:25 pm
    I keep getting a warning / FILE ERROR – UNKNOWN FILE / when I try to save my project file. This happens many times. When it does I trash prefs using fCP rescue. I also fix permissions onthe drive. Things are better after that, but the problem always returns.
    When the problem is happening I can save the file to my raid or to the back drive but not to the system drive.
    Any thoughts?
    b
    Bob Vick sr promo guy @ ch3 wwmt tv, kalamazoo, mi
    Bob Vick replied 21 years ago 2 Members · 4 Replies
  • Arnie Schlissel
    August 22, 2005 at 3:02 pm
    You don’t have any slashes (/) or other illegal characters in the file names, do you? Is the drive full? Assuming you’ve eliminated those, then I’d boot from an OS X startup CD & run the disk tools, followed by Disk Warrior.
    Arnie
    https://www.arniepix.com
  • Bob Vick
    August 22, 2005 at 5:18 pm
    As I look at the title of the project, there is a -in the name. The title is KINGS NITE 6-05. I have had other projects with dates as such. Does the hyphen cause issues? I did try to save as and change the name leaving off the hyphen but no good. Actually it did change the name. The project now reads the new name but it won’t save. I can save the project with the original title to any other drive. I will try to make repairs as suggested.
    b
  • Arnie Schlissel
    August 22, 2005 at 6:13 pm
    Hyphens are OK. I use them all the time in lieu of slashes. Stay away from commas, asterisks, ampersands, quotes & apostrophes.
    How full is the drive?
    Arnie
  • Bob Vick
    August 22, 2005 at 9:43 pm
    [Arniepix] “How full is the drive?
    152 gb capacity
    91 gb available
