Activity › Forums › DaVinci Resolve › File System OS independent
Posted by Ryan Snook on March 24, 2012 at 9:41 pmFor users running dual-boot system or multiple boxes – one windows one mac OSX, what is a good file system for a RAID? Would using a nice Jounaled RAID be cool then having a driver for it on Windows be sufficient?
https://www.paragon-software.com/home/hfs-windows/ ???Any men who have experience fiddling between systems?
Pepijn Klijs replied 14 years, 3 months ago 6 Members · 14 Replies -
Juan Salvo
March 24, 2012 at 10:03 pmMultiple boxes sharing the same media would require a San. Check out stornext/Xsan free for the Mac client.
Ryan Snook
March 24, 2012 at 10:31 pmI meant an external RAID solution connected via eSata on exactly 1 machine at a time… Any further suggestions?
Juan Salvo
March 24, 2012 at 10:55 pmHFS won’t preform very well in Windows, and NTFS doesn’t have native write ability on mac (you can use third party NTFS drivers with write) so either way you will have decreased performs. So just pick which one you will use more often. However, I don’t recommend sharing drives that way.
If you want to have even more fun you could pick a third platform as your filesystem… ext2 has both windows and mac drivers.
Vladimir Kucherov
March 25, 2012 at 12:31 amI have a windows partition on my Mac Pro, and an Apple Raid software raid0 (4 drives)
With the new Mac Drive for windows, I am getting 420 MB/s read write on Windows, which is exactly what I get on the Mac. So, at least synthetic test-wise the performance seems to hold up.
Paul Nordin
March 25, 2012 at 12:57 amHi Vladimir,
Do you have any idea how prior versions of MacDrive for Windows performed? I haven’t upgraded from v8 to v9, yet. But if it performs better I may pay for the upgrade.
I’ve always had problems when copying large data blocks through it. Usually resulting in a lost connection to the drive._______________________
EMB Studios
http://www.EMBstudios.com
Emeryville, CA
_______________________ -
Vladimir Kucherov
March 25, 2012 at 1:10 amI have never used Mac Drive on a RAID before – in fact, I believe they just added the support for apple software raid in this release.
So far it’s been really stable.
There is also something called exFAT, which doesn’t have the file size limitations of FAT32 and is read/writeable by both Mac and Windows.
Ryan Snook
March 25, 2012 at 1:14 amI was just curious about the OWC Mercury Qx2. If i got one of these to have as my RAID (4x2TB Drives) connected via eSata, and wanted to access the RAID one at a time from separate Mac and Windows workstations. The best choice of a file system to format the RAID would be…?
Robert Houllahan
March 25, 2012 at 2:40 amI have been using NTFS Mac on several machines with excellent glitch free results for months now and Mac-Drive on several windows machine without any trouble either. It is good to know that mac-Drive seems to work well on a Raid. I am thinking about a dual boot rebuild of my current machine on the Asus Supercomputer board and it would be nice to have a single raid which works for both OS boots. Too bad both NTFS and HFS+ are older filesystems.
-Rob-
Robert Houllahan
Director / Colorist
Cinelab Inc.
http://www.cinelab.comMAHC-PRO 6-Core 3X GTX285 20Tb SAS Wave Panel Panny 11UK SDI Plasma.
