Activity Forums VEGAS Pro File Storage Format
  • File Storage Format
    Posted by Don Cobble on May 17, 2013 at 4:00 am
    I need to know in what format – or Codec (don’t know correct terminology) to render my projects for storing for later use. With the need of later rendering out: Blu-ray DVDs/ DVDs /Web streaming.
    I shoot in 1920×1080 30P. I normally turn them into a Cineform (High) intermediary for editing.
    So I thought I would render out Cineform High to store; each program is like 30gb! 1 Hour each program (weekly)
    IS there an alternative that will keep a high quality storage maybe not as big. I know you have to balance size with quality – I have been happy with Cineform Quality – but the size is adding up
    PC
    I7 2.8 Ghz 8GB Ram
    Win 7 Pro 64bit OS
    PNY Quadro 4000
    3-4 TB HD
    Vegas 10 64bit & Vegas 11 64Bit & Vegas 12 & Adobe Production Premium CS5.5.2 & Avid Media Composer 5.5
    Camera
    Sony EX1 shoot in 1920×1080 30P
    Don Cobble replied 13 years, 4 months ago 3 Members · 3 Replies
  • Simon Laidlaw
    May 17, 2013 at 7:57 am
    Obviously to keep the quality you need to err on the side of caution. I output 1 hour long broadcast projects via the quick time codec and they come out at 50GB!
    One that you might want to try is the (free to download) avid DNxHD codec. Vegas will pick it up (after a re-boot) and you’ll find it in the quicktime render settings. It is still a .mov file but you can adjust the Mbps to something like 35 which would probably be good enough for blu-ray and may come out a little smaller than 30 gigs.
    http://www.cutmustard.tv
  • Norman Black
    May 17, 2013 at 3:14 pm
    DNxHD codec comes in a few flavors. DNxHD does not use inter frame compression so it needs much higher bitrates for quality than H.264 for example.
    36Mbps which is only intended for proxy files.
    145Mbps 4:2:2 8-bit
    220Mbps 4:2:2 10-bit
    440Mbps 4:4:4 10-bit
    The proxy format is not a high enough bitrate for storage, IMO, and the others will generate very, very large files due to the high bitrate. Consider that a commercial Blu-ray’s are typically around twenty something Mbps average bitrate.
    Your best file size to quality ratio would be with the AVC format.
  • Don Cobble
    May 17, 2013 at 7:55 pm
    Norman – Thank U
    IF there is possibility of needing to edit the file later is the AVC a good format for maintaining the quality like (I think cineform is)?
    Which AVC setting would be best for storing for 1980×1020 30P? any recommendations?
    PC
    I7 2.8 Ghz 8GB Ram
    Win 7 Pro 64bit OS
    PNY Quadro 4000
    3-4 TB HD
    Camera
