Activity Forums VEGAS Pro File size too large???
  • File size too large???
    Posted by Rodney Ballard on February 19, 2007 at 5:23 am
    I am using Sony Vegas Studio 6.0 and DVD Arch. Studio 3.0.
    It seems that all of a sudden my file size is much larger than before, after rendering into MPEG-2. I have 124 minutes of video, and in the past this fit nicely on a single 4.7GB single layer DVD disk. But after importing to DVD Arch. Studio 3.0, it says that it is 7.6GB.
    My settings for rendering are:
    Format: Main Concept MPEG-2
    Template: DVD NTSC
    Description: Audio 224 Kbps, 48,000 Hz, Layer 2
    Video: 29.97 FPS, 720×480
    Perhaps there is a setting I am not aware of that is increasing the file size? Or perhaps the setting that needs to be changed is in the DVD Arch program?
    As a side note, the dual layer disk buring capability of the 6.0 version (over the 4.0) is great, just make sure that the intended audiance has a machine that will play dual layer format.
    Thanks in advance,
    rodent
    Edward Troxel replied 19 years, 6 months ago 3 Members · 2 Replies
  • Anoni Moose
    February 19, 2007 at 7:55 am
    “As a side note, the dual layer disk buring capability of the 6.0 version (over the 4.0) is great, just make sure that the intended audiance has a machine that will play dual layer format.”
    Note that most “normal” DVD’s one would buy with movies on them are dual layer. IOW, all DVD players handle dual layer.
  • Edward Troxel
    February 21, 2007 at 1:27 am
    Since you’re on the “movie studio” version, you can’t control the bitrate of the MPEG2 encoding so you can’t make it smaller. However, you CAN render to DV-AVI and give that to DVD Architect Movie Studio which will then render to MPEG2 of a proper size to fit on the disc.
    Edward Troxel
    JETDV Scripts
