Activity › Forums › Compression Techniques › file size too big
file size too big
Posted by Reonna Cuevas on March 13, 2009 at 8:29 pmIve made a intro for a website using cinema 4d then ae brought it into flash mx to add the actionscripting. my swf is like 37mb and i need to get it to 3mb, I cant get this right any help would be great,
Daniel Low replied 17 years, 6 months ago 2 Members · 3 Replies -
Daniel Low
March 13, 2009 at 8:49 pmPlease tell us more about your animation, like how long it is, the frame size, what Flash video settings you’ve tried etc etc etc etc.
Two years from now, spam will be solved. – Bill Gates, World Economic Forum 2004 -
Reonna Cuevas
March 14, 2009 at 6:34 pmits a 34 sec animation, when i export it from ae into a swf its 1110 frames, in cinema 4d it was a 600 fr animation. I used to have a partner that took over after i did the design work and now im pulling my hair out because im not really good at the getting it ready for the web part. Its 1080/720 and the client wants it down to 4 mb, plus i have flash mx.
Daniel Low
March 15, 2009 at 1:00 amOk, sounds like you are in a bit of a mess..
Are you working with PAL 25FPS, NTSC 30FPS OR HD 24FPS?
make sure you have a consistent frame rate throughout your workflow
[reonna cuevas] “Its 1080/720 and the client wants it down to 4 mb”
It’s either 1920x1080
or 1280x720Which one does the client want?
