Activity Forums Apple Final Cut Pro Legacy File size shrinks after Log and Transfer??
  • File size shrinks after Log and Transfer??
    Posted by Chris Jones on June 30, 2012 at 12:51 am
    Just curious..
    I have Log and Transferred 2 64GB P2 cards in FCP7 that were full (the even wrote over to the second card in my camera)
    After I logged and Transferred the MXF to MOV files with FCP I have found that what were 63ish GB sized CONTENTS folders are now 51ish GB sized folders filled with all the MOV files.
    I thought maybe they were compressed, but when I compare any single MXF file to its MOV file copy, the MOV file is slightly larger – which was a relief – since I don’t want any compression.
    But I am curious why the overall folders are smaller after the L&T.
    Anyone know?
    Shane Ross replied 14 years, 2 months ago 2 Members · 3 Replies
  • Shane Ross
    June 30, 2012 at 1:16 am
    There are other files on the P2 card that might not come over, like ICONs and PROXYS. And if you recorded 8 channels of audio, but only imported 2…that might be it.
    Shane
    Little Frog Post
  • Chris Jones
    June 30, 2012 at 2:27 pm
    [Shane Ross] “d if you recorded 8 channels of audio, but only imported 2…that might be i”
    That made sense until I checked it and they were the same!
    But then it dawned on me. I shot at 1080 24PA. I’m guessing the advanced pulldown would reduce the overall sized of the data I shot?
  • Shane Ross
    July 1, 2012 at 6:55 am
    Yes…it will remove frames….thus the file size will be smaller.
    Good catch.
    Shane
    Little Frog Post
